16.12.2010, 05:06 GMT-5
if you have a heat source of 25[W] for a given volume, the average heat density you should apply is for a 3D domain
Q[W/m^3] = 25[W]/(your_ domain_volume[m^3])
the your_domain_volume is obtained by a integration variable (or volume operator in V4) of "1" as integrand.
What you must catch with COMSOL is that the values you enter in the GUI fields are defined "per FEM element" of size dV=dx*dy*dz (in Cartesian) so you enter body forces in [N/m^3] and heat in [W/m^3] etc with the assumption that you integrate over the applicable domains.
for 2D nothing changes, but COMSOL assumes its working in 3D with a depth of ".d" or ".thickness" (by default = 1[m] for most physics) so then you must multiply you integrand (on a surface by 1*solid.d for a ST case.
In 2D-axi it is the "loop length" that matters which is "2*pi*r"
17.12.2010, 07:42 GMT-5
hey ivar,
thanks for you quick reply. theoretically i understand what you told me, but i have a problem in v4 to find the volume operator you mentioned, because i'm new at v4
thanks for your help and have a nice weekend!
jaques
hey ivar,
jaques
17.12.2010, 10:45 GMT-5
the coupling variables are in v4 defined as "Definitions Model Couplings Iintegration" on a domain
