Changing band gap value when temperature is changed
I am using semiconductor module to study change in silicon energy level when it is brought into contact with a metal. Silicon properties can be obtained from material library. Some properties like band gap is temperature dependent. My question is, do I need to change the values of these properties when I change temperature? Or does COMSOL itself adjust the values based on the given temperature?
Thank you
0 Replies Last Post 09.08.2016, 12:45 GMT-4
Hello Sangyeop Lee
