Hii everyone
I am working on comsol 5.0 and am facing problem on passing two fluids (air, liquid solution) through single domain.Even i have tried 2 different inlets and outlets for 2 different fluids but after selecting 1 material in domain the other automatically overidden itself and in results it is not showing mass tranfer or diffusion .
please help me guys in physics selection.
1 Reply Last Post 25.07.2016, 14:43 GMT-4
Posted: 8 years ago 25.07.2016, 14:43 GMT-4
Hello Gunendra,
It sounds like you are trying to model a two-phase flow situation. It is not clear from your posting what module(s) your license carries.
A quick introduction to multiphase flow modeling capabilities in the COMSOL software is available here:
www.comsol.com/blogs/which-multiphase-flow-interface-should-i-use/
What fluid flow capability comes with which module is summarized here:
www.comsol.com/products/specifications/fluid-flow/
Hello Gunendra, It sounds like you are trying to model a two-phase flow situation. It is not clear from your posting what module(s) your license carries. A quick introduction to multiphase flow modeling capabilities in the COMSOL software is available here: https://www.comsol.com/blogs/which-multiphase-flow-interface-should-i-use/ What fluid flow capability comes with which module is summarized here: https://www.comsol.com/products/specifications/fluid-flow/ Best regards, Jeff
