Looped Electro Thermal Simulation in the Frequency Domain
Dear all,
I'm currently trying to perform an electro-thermal simulation, where I calculate the average joule heating in the frequency domain and use this result in a time dependent study calculating the heat distribution.
To improve my results, I introduced a for loop inside my solution and iterate between these two steps. Such that the execution flow looks like:
Step 1: Freq domain (ec) (only initializes a solution)
begin for
Step 2: Freq domain (ec)
Step 3: Time dependent (ht)
end for
Now I want to update the simulation time for step 3 depending on the parameter of the current iteration. Furthermore, I need to decrease the applied current (still sinusoidal) depending on the current simulation time. Is there a way to access these variables? I'd rather try to avoid matlab for license reasons. But if needed, I can use it.
Thanks in advance.
Philipp
1 Reply Last Post 15.06.2016, 03:27 GMT-4
Sven Friedel COMSOL Employee
Posted: 9 years ago 15.06.2016, 03:27 GMT-4
Dear Philipp
COMSOL has a special built-in functionality for exactly that type of problem. It is called study type "Frequency-Transient". There is little need for manual work because the necessary updating steps are already built-in.
You find a tutorial that uses it here:
www.comsol.ch/model/inductive-heating-of-copper-cylinder-148
Additional information can be found here:
www.comsol.ch/search/?s=%22Frequency-Transient%22&subset=blog
Best regards
Sven Friedel
Dear Philipp COMSOL has a special built-in functionality for exactly that type of problem. It is called study type "Frequency-Transient". There is little need for manual work because the necessary updating steps are already built-in. You find a tutorial that uses it here: https://www.comsol.ch/model/inductive-heating-of-copper-cylinder-148 Additional information can be found here: https://www.comsol.ch/search/?s=%22Frequency-Transient%22&subset=blog Best regards Sven Friedel
