Mapping from 2D to 3D in axisymmetric case with moving mesh
Hey,
I have results from a 2D axisymmetric model of a micro pump.To solve the problem I have used ALE and FSI. Now I need to map the results in 3D. I have actually done that using the initial mesh. Is it possible to do it on the moving mesh also? I have tried doing that but it shows the results at the reference mesh and nothing on the deformed mesh. Is there any way to do that?
Amer
7 Replies Last Post 27.11.2010, 11:56 GMT-5
Posted: 1 decade ago 25.11.2010, 15:27 GMT-5
are you in 3.5 or v4 ?
Hi are you in 3.5 or v4 ? -- Good luck Ivar
Posted: 1 decade ago 25.11.2010, 16:42 GMT-5
Hey Ivar,
On my lab computer, I am using 3.5.
Although, I have v4 on my laptop but I haven't really gotten my hands dirty on it.
Amer
Hey Ivar, On my lab computer, I am using 3.5. Although, I have v4 on my laptop but I haven't really gotten my hands dirty on it. Regards, Amer
Posted: 1 decade ago 26.11.2010, 03:05 GMT-5
I'm not sure how to in 3.5 (any longer).
In >=4.1 it's a specific subnote (must admit I havent tried for ALE but why shouldnt it be ok ?)
Hi I'm not sure how to in 3.5 (any longer). In >=4.1 it's a specific subnote (must admit I havent tried for ALE but why shouldnt it be ok ?) -- Good luck Ivar
Posted: 1 decade ago 26.11.2010, 06:01 GMT-5
Hey again,
This is what I get if I map on ALE mesh. Could it be because of resolution?
It doesn't plot where the mesh has deformed.
(I am attaching the image.)
// Amer
Hey again, This is what I get if I map on ALE mesh. Could it be because of resolution? It doesn't plot where the mesh has deformed. (I am attaching the image.) // Amer
Posted: 1 decade ago 26.11.2010, 08:10 GMT-5
If I well understood your problem, you are trying to revolve your solution from 2D axial-symmetric to 3D. This is possible and quite easy. There is a step by step model in the doc.
However, I think that the ALE solution (motion of your mesh) cannot be revolved!! You need to get it in a full 3D model.
I hope it helps
Hi, If I well understood your problem, you are trying to revolve your solution from 2D axial-symmetric to 3D. This is possible and quite easy. There is a step by step model in the doc. However, I think that the ALE solution (motion of your mesh) cannot be revolved!! You need to get it in a full 3D model. I hope it helps
Posted: 1 decade ago 26.11.2010, 08:16 GMT-5
Strange, unfortunately I do not have 3.5 with me ;) cannot say more
Hi Strange, unfortunately I do not have 3.5 with me ;) cannot say more -- Good luck Ivar
Posted: 1 decade ago 27.11.2010, 11:56 GMT-5
Hej,
Thanks for your replies!
Can anyone come up with an example in v4? (without ALE). I could try it and lets see if that would work with ALE too.
Amer
Hej, Thanks for your replies! Can anyone come up with an example in v4? (without ALE). I could try it and lets see if that would work with ALE too. Regards, Amer
