How do I set up COMSOL so that the material properties parameters of the second study varies with the first solution as an initial condition?
I'm modeling thermal conductivity as a function of temperature rise due to stimulation. For this, I solved study 1 with user defined thermal conductivity (material properties) and temperature and used its solution as an initial conditions for the next study (study 2). But doing so, I will not be capturing the change in thermal conductivity as a function of temperature due to stimulation at that instance.What will be the best way to set up the model for this approach so that the thermal conductivity will be a function of local temperature rise after stimulation (at any time point) for one study and the solution from that can be fed as an initial condition for subsequent studies?
How do I set up COMSOL so that the material properties parameters of the second study varies with the first solution as an initial condition? - ResearchGate. Available from: www.researchgate.net/post/How_do_I_set_up_COMSOL_so_that_the_material_properties_parameters_of_the_second_study_varies_with_the_first_solution_as_an_initial_condition [accessed May 6, 2016].
0 Replies Last Post 06.05.2016, 13:19 GMT-4
Hello Nick Tamang
