[COMSOL 4.3a] How to set initial stress and strain in Solid Mechanics module?
When I double-click "Linear Elastic material", there is only "Damping" option, no "Initial stress and strain" option. Is there a way to set initial stresses and strains?
4 Replies Last Post 16.04.2016, 12:01 GMT-4
Posted: 9 years ago 16.04.2016, 07:51 GMT-4
It sounds like you do not have the Structural Mechanics Module license active.
To see how different features are licensed, please visit
www.comsol.com/products/specifications/structural-mechanics/
Henrik
Hi, It sounds like you do not have the Structural Mechanics Module license active. To see how different features are licensed, please visit https://www.comsol.com/products/specifications/structural-mechanics/ Regards, Henrik
Posted: 9 years ago 16.04.2016, 10:30 GMT-4
Dear Mr. Sönnerlind, thank you for you reply.
I do have Structural Mechanics Module license active and I can use it for calculations. The only thing missing is initial stress and strain setting.
Dear Mr. Sönnerlind, thank you for you reply. I do have Structural Mechanics Module license active and I can use it for calculations. The only thing missing is initial stress and strain setting.
Posted: 9 years ago 16.04.2016, 11:38 GMT-4
Go to Options->Licenses and check the status of the 'Structural Mechanics Module' check box.
With Structural Mechanics Module license on, there should be three sub-options when right-clicking Linear Elastic Material:
- Thermal Expansion
- Initial Stress and Strain
- Damping
If you add the Damping node, there should be four different choices in the 'Damping type' list. Without the license, there is only one.
Henrik
Hi, Go to Options->Licenses and check the status of the 'Structural Mechanics Module' check box. With Structural Mechanics Module license on, there should be three sub-options when right-clicking Linear Elastic Material: - Thermal Expansion - Initial Stress and Strain - Damping If you add the Damping node, there should be four different choices in the 'Damping type' list. Without the license, there is only one. Regards, Henrik
Posted: 9 years ago 16.04.2016, 12:01 GMT-4
Thank you very much for your help!
Anna
Thank you very much for your help! Best regards, Anna
