Can I extract the algorithm that corresponds to the COMSOL solution?
Panagiotis Dimakopoulos
Hi!
I would like to extract the code of a COMSOL file so that I can interfere when ever I want,
How can I do that? Is there any idea?
Thank you in advance!
PD
3 Replies Last Post 24.02.2017, 08:30 GMT-5
Posted: 9 years ago 13.04.2016, 19:49 GMT-4
What do you mean by Extraction of algorithm? As far as I know, COMSOL is not an open-source code, hence not possible to obtain the source code.
Pu, ZHANG
DTU Fotonik
What do you mean by Extraction of algorithm? As far as I know, COMSOL is not an open-source code, hence not possible to obtain the source code. -- Pu, ZHANG DTU Fotonik
Posted: 9 years ago 16.04.2016, 14:30 GMT-4
Hi again,
I am aware of this fact. But I have some thoughts.
First of all I have on my mind the ANSYS software example, where I can extract the model of my problem in a .txt file in a code form. This is feasible in ANSYS software as there are commands that helps me to convert each simulation to an algorithm.
But COMSOL does not include something relative. As I know, I should use the LiveLink for MATLAB.
Then, using MATLAB I can write a code which will do the same thing as the model which I did construct in the COMSOL interface.
And my question is,
Do I have the possibility to extract a (MATLAB) code form COMSOL interface as I do it in ANSYS software? (I don't mean that COMSOL is an open-source code)
P.S. The code that I write in ANSYS software doesn't have any relationship with MATLAB. I use it as an example.
Thank you in advance for your time
Hi again, I am aware of this fact. But I have some thoughts. First of all I have on my mind the ANSYS software example, where I can extract the model of my problem in a .txt file in a code form. This is feasible in ANSYS software as there are commands that helps me to convert each simulation to an algorithm. But COMSOL does not include something relative. As I know, I should use the LiveLink for MATLAB. Then, using MATLAB I can write a code which will do the same thing as the model which I did construct in the COMSOL interface. And my question is, Do I have the possibility to extract a (MATLAB) code form COMSOL interface as I do it in ANSYS software? (I don't mean that COMSOL is an open-source code) P.S. The code that I write in ANSYS software doesn't have any relationship with MATLAB. I use it as an example. Thank you in advance for your time
Posted: 8 years ago 24.02.2017, 08:30 GMT-5
Reading between the lines of your post, I get the sense that you think creating the .m file from scratch is your only option. It is not. You can save a model you've created in the COMSOL graphical user interface as a .m file.
See the Introduction to LiveLink for MATLAB manual, version 5.2a, page 28.
Reading between the lines of your post, I get the sense that you think creating the .m file from scratch is your only option. It is not. You can save a model you've created in the COMSOL graphical user interface as a .m file. See the Introduction to LiveLink for MATLAB manual, version 5.2a, page 28. Best, Jeff
