How to add shear strain as a boundary condition?
I have a squre domain, how can I constraint the displacement of boudary condition to make the squre have a shear deformation?
1 Reply Last Post 30.10.2010, 04:24 GMT-4
Posted: 1 decade ago 30.10.2010, 04:24 GMT-4
take a look at the "roller" BC's but this will also restrain the "height", next is with V4 and the rigid connector you can block a rotation, but you might get other "side effects" depends what you are modelling
Hi take a look at the "roller" BC's but this will also restrain the "height", next is with V4 and the rigid connector you can block a rotation, but you might get other "side effects" depends what you are modelling -- Good luck Ivar
