Problem with 1-D Plotting
[SOLVED]
Hi. I have a problem. I created a 3D model of a mirror with a boundary heat source simulating incident laser beam. I'd like to plot the total displacement of a front surface of a mirror as a function of displacement along the z axis from center point.
Ive created 1D group in result section, added line graph, solid.disp [um] as y-axis, and z-axis [mm] as a x-axis and nothing happens. Im stuck here, because i tried (at least I think i did) everything. Any ideas, solutions?
1 Reply Last Post 28.10.2010, 09:40 GMT-4
Posted: 1 decade ago 28.10.2010, 09:40 GMT-4
solid.disp so I assume V4 ?
have you triesd the Cut Line plots ? and are you sure you want disp and not just "w"
Hi solid.disp so I assume V4 ? have you triesd the Cut Line plots ? and are you sure you want disp and not just "w" -- Good luck Ivar
