Export data of Point Graph
In Comsol 4.0a, is it possible to export data from a 1D Point Graph towards txt file ? In the case where the x coordinate corresponds to a geometrical parameter (a radius of the geometry of my model), the exported file contains only the header and not the x,y data of the curve!
7 Replies Last Post 16.10.2010, 08:22 GMT-4
Posted: 1 decade ago 14.10.2010, 18:21 GMT-4
have youtried the excel format export ? (havnt 4.0a on ym PC here to test)
Hi have youtried the excel format export ? (havnt 4.0a on ym PC here to test) -- Good luck Ivar
Posted: 1 decade ago 14.10.2010, 22:20 GMT-4
It seems that there is no excel format export in comsol4 (Is it true?), I only find the .txt file option.
[QUOTE] Hi have youtried the excel format export ? (havnt 4.0a on ym PC here to test) -- Good luck Ivar [/QUOTE] It seems that there is no excel format export in comsol4 (Is it true?), I only find the .txt file option.
Posted: 1 decade ago 15.10.2010, 00:51 GMT-4
Thank you for the answer. I tried "Spreadsheet" and "Sectionwise" data format and both didn't work. Furthermore, both data format correspond to a txt format. I don't see how to export toward a Excel format?
Thank you,
Guy
Hi, Thank you for the answer. I tried "Spreadsheet" and "Sectionwise" data format and both didn't work. Furthermore, both data format correspond to a txt format. I don't see how to export toward a Excel format? Thank you, Guy
Posted: 1 decade ago 15.10.2010, 01:46 GMT-4
then its in Excel compatible txt format, try a convert data to table in Excel
Hi then its in Excel compatible txt format, try a convert data to table in Excel -- Good luck Ivar
Posted: 1 decade ago 15.10.2010, 03:03 GMT-4
Probably, I badly explained. The problem is that the txt exported file is empty and it only contains the header data such as.
But I found a solution !!!
I used a "Model Couplings" Definitions. Then, after computing, I plotted a 1D Global plot. In this case the Exported Data txt file contains all the data (header + x,y points).
Guy
Hi, Probably, I badly explained. The problem is that the txt exported file is empty and it only contains the header data such as. But I found a solution !!! I used a "Model Couplings" Definitions. Then, after computing, I plotted a 1D Global plot. In this case the Exported Data txt file contains all the data (header + x,y points). Thanks, Guy
Posted: 1 decade ago 16.10.2010, 04:45 GMT-4
Good approach.
One other thing, if you define a new coupling or operator, for postprocessing, you do not need to fully rerun your study, a: Study - SolverConfig - Solver - Solution - Update will do the job, and is mostly quicker
Hi Good approach. One other thing, if you define a new coupling or operator, for postprocessing, you do not need to fully rerun your study, a: Study - SolverConfig - Solver - Solution - Update will do the job, and is mostly quicker -- Good luck Ivar
Posted: 1 decade ago 16.10.2010, 08:22 GMT-4
Thank you Ivar!
Guy
Thank you Ivar! Guy
