Manipulation of imported CAD files with Java API
I am using the COMSOL Java API to create an acoustics model programmatically. In the model, I want to import a CAD file (specifically a .sldprt or .asm from Solidworks), and then automatically assign impedance boundary conditions to certain surfaces, say an exit nozzle. In Solidworks, I am able to attach a specific label to any surface or volume of interest, but when I try import that geometry into COMSOL, as far as I am aware that information is lost. All the elements of the imported CAD geometry are identified only by a number in a more-or-less arbitrarily ordered list. Is there any way to recover such information upon importing a CAD file using the API?
2 Replies Last Post 15.02.2016, 08:14 GMT-5
Lorant Olasz COMSOL Employee
Posted: 9 years ago 12.02.2016, 11:39 GMT-5
Hi Christopher,
A good way to do this with file import would be to use an appropriate coordinate based selection for the boundary conditions. Check out the ball, box and cylinder selections located on the Geometry tab, and in the user's guide.
If you have LiveLink for SOLIDWORKS you would instead synchronize the geometry using the LiveLink interface and define selections for the boundaries in SOLIDWORKS using the LiveLink.
Lorant
Hi Christopher, A good way to do this with file import would be to use an appropriate coordinate based selection for the boundary conditions. Check out the ball, box and cylinder selections located on the Geometry tab, and in the user's guide. If you have LiveLink for SOLIDWORKS you would instead synchronize the geometry using the LiveLink interface and define selections for the boundaries in SOLIDWORKS using the LiveLink. Best, Lorant
Posted: 9 years ago 15.02.2016, 08:14 GMT-5
Thankyou, I think that may help to solve my problem!
