applying thickness in 2D
Posted 12.01.2016, 04:51 GMT-5 0 Replies
I have simulated droplet generation in 2D microchannel successfully with inlet flow rate boundary condition. There is entrance thickness parameter in that case that through which we can change the thickness as much as we want. On the other hand, when I switched to the pressure inlet boundary condition, there is no option to change the thickness. As I know Comsol thickness in 2D is 1m by default. I do not know how I can change that. In addition, some thing weird happen when I use pressure inlet condition to simulate the droplet generation in T-junction. I am using Comsol.5.
I will be glad if you help me. Thanks in advance.
Ali Kalantarifard
Hello Ali Kalantari
