concentration jumps in transport of diluted species model
I have transport of diluted species model defined on two domain with one interior boundary condition, and I want to define a concentration jumps at the interior boundary. Let's says the ratio of the concentration at the interior boundary is some value 0.5. By the way, there is flux discontinuity already defined there.
Anyone knows how to do it?
thanks,
Hansong
6 Replies Last Post 14.01.2016, 20:48 GMT-5
Posted: 9 years ago 12.01.2016, 04:30 GMT-5
I have done what you asked by using two physics nodes, one for each domain. Let's say that in domain 1 you have concentration C1 and in domain concentration C2 (they are the same molecules but in different domains). At the internal boundary, in domain 1 define
C1 = P*C2
and in domain 2
C2 = C1/P
and P is the partition coefficient between the domains.
For closer details, you can have a look at
dx.doi.org/10.1016/j.mbs.2014.03.014
BR
Lasse
I have done what you asked by using two physics nodes, one for each domain. Let's say that in domain 1 you have concentration C1 and in domain concentration C2 (they are the same molecules but in different domains). At the internal boundary, in domain 1 define C1 = P*C2 and in domain 2 C2 = C1/P and P is the partition coefficient between the domains. For closer details, you can have a look at http://dx.doi.org/10.1016/j.mbs.2014.03.014 BR Lasse
Posted: 9 years ago 12.01.2016, 08:17 GMT-5
Hi Lasse,
thanks for the reply. How about define flux discontinuity when have two physics nodes? Shall I use the same way you mentioned below for defining flux discontinuity or I can use identity pairs for it?
regards,
Hansong
Hi Lasse, thanks for the reply. How about define flux discontinuity when have two physics nodes? Shall I use the same way you mentioned below for defining flux discontinuity or I can use identity pairs for it? regards, Hansong
Posted: 9 years ago 12.01.2016, 08:23 GMT-5
I do not understand these identity pairs, never used them.
Flux discontinuity is formed if you define different fluxes in domain 1 and 2 at the boundary. But as you certainly understand, flux discontinuity means accumulation or depletion of material at the interface.
BR
Lasse
I do not understand these identity pairs, never used them. Flux discontinuity is formed if you define different fluxes in domain 1 and 2 at the boundary. But as you certainly understand, flux discontinuity means accumulation or depletion of material at the interface. BR Lasse
Posted: 9 years ago 13.01.2016, 03:57 GMT-5
As what you said above, I use two physics nodes, one for each domain. And I set the concentration and flux are continuous across the internal boundary, but now it is not converged. Do you know any idea why? The difference is just that when I use 1 physics node defined on two domain, by default the concentration and the flux are continuous and it is converged.
thanks,
Hansong
As what you said above, I use two physics nodes, one for each domain. And I set the concentration and flux are continuous across the internal boundary, but now it is not converged. Do you know any idea why? The difference is just that when I use 1 physics node defined on two domain, by default the concentration and the flux are continuous and it is converged. thanks, Hansong
Posted: 9 years ago 13.01.2016, 04:07 GMT-5
I need to see the model file, can you submit to me privately?
Lasse
I need to see the model file, can you submit to me privately? Lasse
Posted: 9 years ago 14.01.2016, 20:48 GMT-5
Hi Lasse,
I have figured out my problem already. It is just the sign of flux at the internal boundary which cause not convergence.
thanks,
Hansong
Hi Lasse, I have figured out my problem already. It is just the sign of flux at the internal boundary which cause not convergence. thanks, Hansong
