Failed to find consistent initial values
Posted 21.05.2014, 14:53 GMT-4 Studies & Solvers Version 4.4 0 Replies
However, I'm working on a two phase flow problem using the Darcy flow module and I want to start with a 2-D box completely saturated with water (the wetting fluid) into which I introduce a second fluid (non-wetting, with greater density) at a known velocity. The only way I've been able to get the model to converge is to give the model unrealistic initial conditions. Any suggestions would be greatly appreciated.
Hello Michelle Roberge
