how to reinitialize model components within an external script...?
I am wondering which command to use in order to reinitialize/reset a mode orl some parts of a model such as, model.sol, model.study, model.mesh.. and so forth,
during the course of an externally controlled script that run a comsol model.
I have tried things like
" model.physics.clear" and their likes but they do not work obviously, so when the script try to execute for a second time say, "model.physics", it stops telling me the study already exists....
I cannot find anything in the comsol api doc or matlab livelink on this subject. [ or I dont know where to look and th e various indexes does not provide any clues... and still have to put my hand on one example where this feature will be used....
Any suggestion??? it must be pretty basic I am sure
3 Replies Last Post 24.09.2010, 09:50 GMT-4
Posted: 1 decade ago 24.09.2010, 08:05 GMT-4
sorry cannot help, for that one, I have not had time to study the API yet.
In the GUI I suppose you are referring to the << File - Reset history >>
Hi sorry cannot help, for that one, I have not had time to study the API yet. In the GUI I suppose you are referring to the > -- Good luck Ivar
Posted: 1 decade ago 24.09.2010, 08:16 GMT-4
Ivar,
Thanks for reading
I think it is more complex than that
It is related tp the proper way to run a comsol model from matlab and pass some parameters that will be calculated from matlab to comsol
that can on a case by case basis, either change the physics settings, the meshing or the geometry or a combination of both..
JF
Ivar, Thanks for reading I think it is more complex than that It is related tp the proper way to run a comsol model from matlab and pass some parameters that will be calculated from matlab to comsol that can on a case by case basis, either change the physics settings, the meshing or the geometry or a combination of both.. JF
Posted: 1 decade ago 24.09.2010, 09:50 GMT-4
partrtially answering my own question..
might be useful for others.. going alontg the same way...
"model.batch" is the solution to my initial problem
JF
partrtially answering my own question.. might be useful for others.. going alontg the same way... "model.batch" is the solution to my initial problem JF
