Twisted helical coil
I'm wondering whether it's possible to create a helical coil, which is twisted into a circular shape? (Like a torus but with a helix instead).
Any help would be much appreciated!
1 Reply Last Post 29.07.2015, 01:52 GMT-4
Posted: 9 years ago 29.07.2015, 01:52 GMT-4
I'm not sure I understand what you want, is it a poloidal twist of a torus ?
Because the COMSOL Helix, for topology reasons I suspect, cannot be made loop into itself to close its volume (at least I do not see how ;).
But you might be able to define a coordinate system that twists like a poloidal rotation, check the blog on the rotating frames
Hi I'm not sure I understand what you want, is it a poloidal twist of a torus ? Because the COMSOL Helix, for topology reasons I suspect, cannot be made loop into itself to close its volume (at least I do not see how ;). But you might be able to define a coordinate system that twists like a poloidal rotation, check the blog on the rotating frames -- Good luck Ivar
