covering two parametric surface into a solid object
I use two parametric function to define two function, and want to generate a solid object based on the parametric surface. However, I don't know why I just could not do the conversion (empty output). could anyone please help me with this probelm.
2 Replies Last Post 30.07.2015, 19:24 GMT-4
Posted: 9 years ago 29.07.2015, 10:25 GMT-4
Hi Ramsay,
The surface is not really closed when you let it run from 0-2*pi, so I advise to split the surface in two, one from 0-pi, one from pi-2*pi. And then combining these. You might need to modify the repair tolerances a bit though (not in this example).
Attached your kiwi fruit, which even meshes easily.
Frank
Hi Ramsay, The surface is not really closed when you let it run from 0-2*pi, so I advise to split the surface in two, one from 0-pi, one from pi-2*pi. And then combining these. You might need to modify the repair tolerances a bit though (not in this example). Attached your kiwi fruit, which even meshes easily. Best regards, Frank
Posted: 9 years ago 30.07.2015, 19:24 GMT-4
Thank you very much Frank, it work now. cheers
