Hello Martin Suter
20.06.2011, 09:04 GMT-4
Did you find an answer for this issue? I have exactly the same problem.
20.09.2011, 13:27 GMT-4
Same Problem...
Could someone give an answer?
Same Problem...
21.09.2011, 02:57 GMT-4
No solution so far ...
21.09.2011, 03:44 GMT-4
Manualy:
ctrl + pause/break
Using script - check the documentation of a function that you use... Try to find where "the evaluation of convergance" is calculated and write proper condition..
Rafał Piotuch
Manualy:
ctrl + pause/break
Rafał Piotuch
22.09.2011, 10:37 GMT-4
Dear Rafal Piotuch,
I don't quiet see what you mean!
Could you please be more precise?
Cheers
Dear Rafal Piotuch,
Cheers
23.09.2011, 01:16 GMT-4
Dear Julien Egger;
sure:) Hope you use Matlab to solve problem, else I don't know how to help you:)
So.. If you use Matlab it is easy to stop simulation manualy- just press ctr+pause/break and the simulation stops after some time - but for sure you want to stop simulation automaticly, without any human control...
When you solve sth. using for example femtime function.. read documentation of such function and read script of this function - there must be a "place" in code that refers to convergance calculation... So there must be a variable that stores current step_size.. If you will write in pseudo code:
if (step_size<0.0001) then
%the function return sth, so it should be stopped or proper value should be returned.
return(0);
it should be working.
So that's all.
Rafał Piotuch
Dear Julien Egger;
if (step_size
30.11.2012, 06:32 GMT-5
look up the global variable "timestep" in the comsol documentation. It does exactly what you want :)
