05.08.2010, 04:24 GMT-4
I would be suspicous particuluarly with respect to the message:
There are 80 degrees of freedom giving NaN/Inf in the vector for the variable mod1.T
at coordinates: (0,5.5633e-005,9.48117e-005),....
for me this looks like there is something missing in the boundary conditions or a T value not defined (could be used in thematerial section if you are using library material depending on T and T is not defined
05.08.2010, 08:22 GMT-4
I changed the solver setting from segregated to Fully coupled. And there is no more error message.
But I still got the following warning message:
Inverted mesh element near coordinates (0.000116793, 9.90577e-005, 9.88431e-005);
Do I need to concern this message?
05.08.2010, 10:52 GMT-4
inverted mesh is a warning that locally the mesh quality is bad, if there is only one/a few and the coordinates provided are not in the middle of the most important feature of your model it's not that important.
nevertheless a "good" model should not have any inverted mesh elements, soits also possible to locate the position an try to understand what is happening, perhaps there are some unecesary details to be removed (defeaturing) or it could be supressed by a local edge pre-meshing with a higher density
As often no clear yes/no
06.08.2010, 12:22 GMT-4
Are you solving coupled problem?
06.08.2010, 16:49 GMT-4
The intention of this model is to only demonstrate the use of the Fluid-Structure iteraction feature along with heat transfer physics in COMSOL 4.0a. One can see that the Young's modulus of the flexible obstacle is small and provides a large deformation when influenced by the fluid. This material is not real.
Real FSI situations need to be treated with care but this tutorial will show how to approach such simulations.
best regards,
Mauricio
best regards,
Mauricio
