X window server error comsol 4.0a on ubuntu 10.04
I have a problem starting Comsol 4.0a on Ubuntu 10.04. I get the following error:
The program 'SWT' received an X Window System error.
This probably reflects a bug in the program.
The error was 'BadDrawable (invalid Pixmap or Window parameter)'.
(Details: serial 2350 error_code 9 request_code 136 minor_code 3)
(Note to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it.
To debug your program, run it with the --sync command line
option to change this behavior. You can then get a meaningful
backtrace from your debugger if you break on the gdk_x_error() function.)
Maybe someone has a clue how to solve this problem.
7 Replies Last Post 28.04.2011, 13:00 GMT-4
Posted: 1 decade ago 19.07.2010, 06:00 GMT-4
I have a similar problem when using the X server included with Ubuntu 9.10 (same problem with Comsol 4.0): Also an X Window system error, but a different error code:
The error was '255'.
(Details: serial 5396 error_code 255 request_code 136 minor_code 17)
I have a similar problem when using the X server included with Ubuntu 9.10 (same problem with Comsol 4.0): Also an X Window system error, but a different error code: The program 'SWT' received an X Window System error. This probably reflects a bug in the program. The error was '255'. (Details: serial 5396 error_code 255 request_code 136 minor_code 17) (Note to programmers: normally, X errors are reported asynchronously; that is, you will receive the error a while after causing it. To debug your program, run it with the --sync command line option to change this behavior. You can then get a meaningful backtrace from your debugger if you break on the gdk_x_error() function.)
Posted: 1 decade ago 19.07.2010, 07:50 GMT-4
Can you change the graphic window manager from SWT to Swing in the settings to see if it helps?
Posted: 1 decade ago 19.07.2010, 09:32 GMT-4
By the way: You probably need to try remote X (via SSH) or similar to change this setting as of course Comsol 4.0 won't start because of this error. I'll try this later via remote X with another X server version.
Edit: Actually you could manually edit .comsol/v40/comsol.prefs and insert this line:
graphics.rendering.2drend=swing
By the way: You probably need to try remote X (via SSH) or similar to change this setting as of course Comsol 4.0 won't start because of this error. I'll try this later via remote X with another X server version. Edit: Actually you could manually edit .comsol/v40/comsol.prefs and insert this line: graphics.rendering.2drend=swing
Posted: 1 decade ago 20.07.2010, 07:42 GMT-4
thanks a lot folks. Inserting the code line has solved the problem.
Hi, thanks a lot folks. Inserting the code line has solved the problem.
Posted: 1 decade ago 20.07.2010, 11:34 GMT-4
Yeah, this setting has also solved my problem.
Posted: 1 decade ago 14.01.2011, 11:57 GMT-5
I have the same problem/error with COMSOL 4.1 on Kubuntu 10.04
in my case this doesn't work
and actually it seems my comsol doesn't care about the .comsol/v41/comsol.prefs file on starting (even if I delete the file the error I get is the same)
any other tip?
cheers
f
I have the same problem/error with COMSOL 4.1 on Kubuntu 10.04 [QUOTE] Edit: Actually you could manually edit .comsol/v40/comsol.prefs and insert this line: graphics.rendering.2drend=swing [/QUOTE] in my case this doesn't work and actually it seems my comsol doesn't care about the .comsol/v41/comsol.prefs file on starting (even if I delete the file the error I get is the same) any other tip? cheers f
Posted: 1 decade ago 28.04.2011, 13:00 GMT-4
I have the same problem with 4.1 and ubuntu 10.04. It looks like Comsol 4.1 is not running on Ubuntu 10.04 ...
