Hello Yuankang Lu
9 years ago
24.11.2015, 06:36 GMT-5
May I ask, were you able to solve this problem? Even I have a similar problem and I wish to know how did you manage to solve it?
Especially, the boundary conditions you used for the first part to find displacement field.
Nagi Elabbasi
Facebook Reality Labs
9 years ago
24.11.2015, 12:35 GMT-5
Hi Rijil,
That’s an interesting problem. Thermal expansion (and heating) is usually slow enough that it does not create a significant pressure wave in a surrounding fluid.
Nagi Elabbasi
Veryst Engineering
Hi Rijil,
Nagi Elabbasi
Veryst Engineering
9 years ago
24.11.2015, 13:11 GMT-5
Hi Nagi,
Correct me if I am wrong.
Isn't the same principle of heating and thermal expansion that is being obeyed in photoacoustics?
According to photoacoustics, from what I read, a sudden heating due to a very short laser pulse will cause heating and expansion producing pressure to surrounding medium.
Hi Nagi,
Nagi Elabbasi
9 years ago
24.11.2015, 13:57 GMT-5
Thanks Rijil, you are right. I was not aware of applications involving such a fast rate of change in temperature! So, going back to the original questions. The thermal boundary conditions for the thermal-structural part should in my opinion be a boundary heat flux (spatially varying if necessary) on the surface where the laser is applied to the metal. The structural boundary conditions depend on how the block is held in place. The surface of the solid block should be automatically detected by COMSOL as a shared structural-acoustic boundary. Therefore, COMSOL will set up the correct interface conditions relating water pressure to displacements/velocities/accelerations of the metal block. Depending on the geometry/loading/material properties there may be substantial heating of the water as well, in which case you need a thermoacoustic model of the water as well. COMSOL should again handle the thermal interface conditions between block and water. There is a good COMSOL Model Gallery example called “Photoacoustic Resonator” that you have probably seen already. It has some good details.
Good luck.
Nagi Elabbasi
Veryst Engineering
Good luck.
Nagi Elabbasi
Veryst Engineering
9 years ago
24.11.2015, 22:17 GMT-5
Thank you Nagi for your response.
Can I clarify few more things?
In my case, it is a nanoparticle suspended in a medium. And I know the heat absorbed by the particle. So I modeled the particle in heat transfer physics as a heat source (W/m^3). Do I also need to give the heat flux which is in W/m^2 ? If so, how to convert heat source to heat flux?
Furthermore, it is suspended freely in medium. So how will the structural boundary condition be?
