Hello Basky
10 years ago
22.05.2015, 06:23 GMT-4
I am not able to define heat source which has to move. So, can you please help me to come out of this problem
10 years ago
22.05.2015, 06:58 GMT-4
The equation of heat source contains x,y,z in case of Cartesian coordinates and if you have defined your heat source position as x0, y0, z0 and considering heat source moves along X- axis,
then the equation consists of : [ x - (x0 + vt) ] provided v is the welding speed.
Hope this helps.
Hope this helps.
10 years ago
30.05.2015, 05:36 GMT-4
Hello Basky,
Thank you very much for your help. I came out of that problem. I am very much thankful for you. Can, you please help me is there any inbuilt option to find Residual Stresses?
With Regards
Vinayak S Matur
Hello Basky,
With Regards
Vinayak S Matur
10 years ago
30.05.2015, 05:51 GMT-4
Hello Basky,
I also have one more doubt. I want to define a double ellipsoidal heat source. The equation of heat source changes in three conditions. i.e., for x<0, x==0 and x>0. In Heat Transfer for Solids option I have already defined for hemispherical. But I am not getting how to define Double Ellipsoidal Heat source by using 3 condition. So, can you please tell me how to define this in COMSOL 4.4.
With Regards
Vinayak S Matur
Hello Basky,
I also have one more doubt. I want to define a double ellipsoidal heat source. The equation of heat source changes in three conditions. i.e., for x0. In Heat Transfer for Solids option I have already defined for hemispherical. But I am not getting how to define Double Ellipsoidal Heat source by using 3 condition. So, can you please tell me how to define this in COMSOL 4.4.
With Regards
Vinayak S Matur
9 years ago
28.11.2015, 04:30 GMT-5
hello mathur,
i am also working on some problem that consists of finding thermal residual stresses developed in the processes. can you help me out?
thanks and regard
hello mathur,
thanks and regard
8 years ago
25.07.2016, 04:15 GMT-4
Hello Basky,
With Regards
Vinayak S Matur
Hi Vinayak S Matur,
I am a beginner and I'm trying to model a moving heat source.
Could you help me with giving the heat input as a function of x,y,z?
Thank you in advance,
[QUOTE]
Hello Basky,
With Regards
Vinayak S Matur
[/QUOTE]
Hi Vinayak S Matur,
