Obtaining a stable Convection-Diffusion model
Posted 01.07.2010, 14:01 GMT-4 2 Replies
Hello all,
I am working on a microfluidic mixer with several channels. A couple channels will be inputting water, while two others will serve as the respective inlets for two different molecules at low concentrations. Further, both of these molecules have fairly low diffusion coefficients.
Since I do not believe (but please correct me if I'm wrong) that there is a good way to apply different diffusion coefficients to the mixer to simulate the eventual mixing of these two species, I have been solving for the diffusion of each molecular species separately while the other inlet is set to be inputting water. Note: I am not using the Chemical Engineering module, I am simply using a combination of Navier-Stokes/Convection-Diffusion modules.
However, COMSOL is yielding unphysical results for such low concentrations and diffusion coefficients (e.g. the entire mixer shows a uniform concentration.) I know that the model itself is sound since it gives reasonable results for higher concentrations and diffusion coefficients, so the problem seems to be with these parameters. I have been toying with various artificial diffusion settings and refined the mesh as much as possible, but to no avail.
Does anyone have any suggestions to get good results from this model?
Thanks for your help.
Natalie
Natalie
2 Replies Last Post 02.07.2010, 13:31 GMT-4
