Mapped mesh in 3D
Dear all,
1-I trying to mapped mesh a solid in 3D, but it sends me an error message "Error: 7161:The mass matrix is zero" when i try the eigenfrequency, and yet if the default mesh does not send it.
2-how can I set a damping coefficient?
Achraf
3 Replies Last Post 14.04.2013, 17:18 GMT-4
Posted: 1 decade ago 26.04.2010, 12:09 GMT-4
Dear all,
1- I'm trying to mapped mesh a solid in 3D, but it sends me an error message "Error: 7161:The mass matrix is zero" when I try the eigenfrequency, and yet if the default mesh does not send it.
Achraf
[QUOTE] Dear all, 1- I'm trying to mapped mesh a solid in 3D, but it sends me an error message "Error: 7161:The mass matrix is zero" when I try the eigenfrequency, and yet if the default mesh does not send it. 2-how can I set a damping coefficient? Achraf [/QUOTE]
Posted: 1 decade ago 26.04.2010, 14:21 GMT-4
for me the mapped mesh is mot pobably not the reason for mass matrix is zero (except perhaps if part of the volume is stilll not fully meshed, try to hit the "select remaining" noting should light up), incomplete BC are also potential causes.
For the damping you have the volumic ones and, depending on the application mode therr might be also on the boundary conditons, pick what corresponds to your case. For 3D structural, there are a couple of section related to how to select the damping, as this as a great influence on the resonant peaks, and these are often frequency dependet too, check the doc, in particular the structural
Hi for me the mapped mesh is mot pobably not the reason for mass matrix is zero (except perhaps if part of the volume is stilll not fully meshed, try to hit the "select remaining" noting should light up), incomplete BC are also potential causes. For the damping you have the volumic ones and, depending on the application mode therr might be also on the boundary conditons, pick what corresponds to your case. For 3D structural, there are a couple of section related to how to select the damping, as this as a great influence on the resonant peaks, and these are often frequency dependet too, check the doc, in particular the structural Good luck Ivar
Posted: 1 decade ago 14.04.2013, 17:18 GMT-4
This problem arises when you have a model with sharp edges. Try filing your edges with reasonable fillet radii.
Then apply a mapped mesh to one end face of your model and sweep that mesh along your model.
Problem will be resolved.
Have fun!
Hi This problem arises when you have a model with sharp edges. Try filing your edges with reasonable fillet radii. Then apply a mapped mesh to one end face of your model and sweep that mesh along your model. Problem will be resolved. Have fun!
