Simulating a single layered coil wound directly on top of itself.
We are designing an electromagnet that uses multi-turn coils. The wire making up the coils is to be tape-like and wound directly on top of itself instead of being wound like a solenoid.
Is it possible to get COMSOL to simulate this type of coil design?
The reason I ask is because when we simulate the design for varying number of turns, we observe a linear relationship between the number of turns and the magnetic field produced.
According to the equation; Magnetic Field (B) = [(mu_0)(Current,I)(Number of turns, N)] / (2*Radius), this shouldn't be the case as an increased number of turns should also increase R.
Thanks for the help in advance,
Happy comsoling,
Rob and Callum
5 Replies Last Post 11.11.2014, 13:50 GMT-5
Posted: 1 decade ago 11.11.2014, 08:47 GMT-5
which way are you exciting the coil?
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi, which way are you exciting the coil? Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 1 decade ago 11.11.2014, 08:57 GMT-5
Hi Edgar,
We've defined a single cross sectional surface within the coil through which the current flows.
Rob
Hi Edgar, We've defined a single cross sectional surface within the coil through which the current flows. Thanks, Rob
Posted: 1 decade ago 11.11.2014, 09:48 GMT-5
So I assume you are using current excitation. This enforces constant current. You can change it to voltage excitation and you will probably see the expected behavior.
Edgar J. Kaiser
www.emphys.com
So I assume you are using current excitation. This enforces constant current. You can change it to voltage excitation and you will probably see the expected behavior. -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 1 decade ago 11.11.2014, 10:42 GMT-5
Thanks we've tried to use a voltage input and have observed different behaviour.
We are confused by the fact that a voltage input has led to an increase in magnetic field, as this seems counterintuitive. A quick calculation using the formula for length of wire in a coil has given us a resistance greater than 1 Ohm, suggesting current and field should decrease. Is there a way to find out the process Comsol uses to calculate resistance in the coil?
Thanks again,
Rob and Callum
Hi, Thanks we've tried to use a voltage input and have observed different behaviour. We are confused by the fact that a voltage input has led to an increase in magnetic field, as this seems counterintuitive. A quick calculation using the formula for length of wire in a coil has given us a resistance greater than 1 Ohm, suggesting current and field should decrease. Is there a way to find out the process Comsol uses to calculate resistance in the coil? Thanks again, Rob and Callum
Posted: 1 decade ago 11.11.2014, 13:50 GMT-5
You may have to check the wire setting. For further reference I would recommend the documentation and the COMSOL support.
Edgar J. Kaiser
www.emphys.com
You may have to check the wire setting. For further reference I would recommend the documentation and the COMSOL support. -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
