back flow and Recoverable error in residual,
Posted 06.11.2014, 11:34 GMT-5 0 Replies
I am doing some simulation on Peristaltic pump by using comsol model from the model gallery.But when I am trying to change viscosity to very high,i am getting some error message like"
Recoverable error in residual, but solver could not recover.
Time : 0.3443258342877595
- Feature: Time-Dependent Solver 1 (sol1/t1)"
Also,I am getting back-flow when increasing the viscosity. why?
Can anyone help me to fix them?
In addition,I tried to change viscosity at the pressured part of the tube(when rotor is engaged and applies maximum pressure) as function of time by using the following smoothed unit step function:for water,
vis=.001+x*flc2hs(ts-0.5,0.0001)-.001*flc2hs(ts-0.5001,.9999) and then in material viscosity table call the function by vis(t/dt).
it worked for higher viscosity in pressured part of the tube where changing viscosity x.
As I am very new in comsol,can someone confirm me that the function is OK?
In this case I am getting some back flow as well.why?
Thanks in advance.
Hello Md Fayaz Ahamed
