Modefield overlap with last solution and first parameter
I solve for 6 modes over a parametric wavelength sweep. The higher order modes doesn't get the same solution numer for all wavelengths (due to absorption and refractive index changes with wavelength). So if I want to follow the "TEM01" mode with respect to wavelength I figured that I had to do a mode overlap integral with the "with"-operator.
When deriving values is there a way to do access the 5th solution for the first wavelength?
Eg when I integrate Ex*conj(with(5,Ex)) I only fetch the 5th solution within the same wavelength parameter but I want to integrate it always with the first wavelength parameter.
0 Replies Last Post 02.10.2014, 03:06 GMT-4
Hello Micke Malmström
