Swept mesh
Hi All:
I'm trying to create a swept mesh but I'm getting the following error:
Error: 4129
Source and target faces must be specified.
- Subdomain: 1
The geometry represents a microfluidic device with a Y-shape entry. Basically, two channels running in paralell separated by a middle smaller channel (H-shaped cross section). Any suggestion for this case?
Thanks very much,
-Omar Canales
2 Replies Last Post 08.04.2010, 14:36 GMT-4
Posted: 1 decade ago 08.04.2010, 02:23 GMT-4
Sweep meshing works "automatically" when you have simple items, such as boxes: you mesh one side and ask it to sweep over the rest, but if you have meshed more than 1 side, COMSOL gets confused on "how" to seep, and ask for help.
Take a look at the doc and test it out on simple volumes, there are also limits on the number of distinct surfaces on the "start" = "source" or "stop" = "target" face (I tend to forget on which one ther is a limit).
Furthermore, it only works if the topology of the part remains coherent: no branches, so that if you have a Y you must manually split it up in 4 items, each branch and the combination part, and mesh them by hand one by one.
Start playing with simple volumes, you will quickly get it, I'm sure
Have fun Comsoling
Hi Sweep meshing works "automatically" when you have simple items, such as boxes: you mesh one side and ask it to sweep over the rest, but if you have meshed more than 1 side, COMSOL gets confused on "how" to seep, and ask for help. Take a look at the doc and test it out on simple volumes, there are also limits on the number of distinct surfaces on the "start" = "source" or "stop" = "target" face (I tend to forget on which one ther is a limit). Furthermore, it only works if the topology of the part remains coherent: no branches, so that if you have a Y you must manually split it up in 4 items, each branch and the combination part, and mesh them by hand one by one. Start playing with simple volumes, you will quickly get it, I'm sure Have fun Comsoling Ivar
Posted: 1 decade ago 08.04.2010, 14:36 GMT-4
Thanks for you response. I will try such suggestions!
