2 decades ago
07.04.2010, 13:09 GMT-4
if you define a boandyry load such as Fx=DF*t then you have a ramping force, with scale "DF[N/s]", if you want it to stop after 6 seconds a Fx=DF*t*(t<=6) will do, but then you have some nice spikes that might give you some solver convergence issues, to be tested out, try to set a small time intervalle around the abrupt stop.
Better you can smoothen with a heaviside function search the doc for "flc1h" or a combination of cos or sin functions (to ensure a couple of continuous derivatives), this often helps for the solver convergence
Have fun Comsoling
nagamalleswara rao alluri
2 decades ago
08.04.2010, 13:35 GMT-4
Thanks for the response Ivar
Actually i am applying ramp force 1MN to 30MN with in 6 seconds.
is it possible to give the force with this function Fx=DF*t*(t<=6)
what i am saying is what is the meaning of DF*t* , i couldn't understand.
if possible, could explain clearly.........t is time
and DF means is it a function(like F=ma)?
Nagamalli
2 decades ago
09.04.2010, 01:23 GMT-4
Wellif I understand you correctyl youre force expression is something like
F[MN] = 1[MN]+(30-1)[MN]/(6[s])*t
with this formula you must stp your simulation after 6 seconds, because your force will continue to ramp.
Make a "function" out of this an use the plot functionality to check its shape and values.
If your simulation is to last > 6 sec, but you want to saturate at 30[MN] I would write:
F[MN] = 1[MN]+(30-1)[MN]*min(t/6,1)
does this help ?
HAve fun Comsoling
does this help ?
HAve fun Comsoling
2 decades ago
11.04.2010, 12:57 GMT-4
Thanks Ivar.
this should be useful my project.
Nagamalli
Thanks Ivar.
Nagamalli
