About 3D very thin geometry meshing problem
Posted 27.04.2014, 13:18 GMT-4 Structural Mechanics Version 4.4 1 Reply
I have just wanted to see the thin membrane free vibration in COMSOL 4.4. I have tried to use Solid Mechnics module and Membrane module . I think I have set the physics properly, then meshed , I think the meshing is also ok because no error there , it gives me good mesh. However, as I give compute order then it gives me the ' Singular Matrix ' error . it says there are some number of void equation .
It seems I did not have good quality of meshing for this thin geometry.
I have read ' Membrane Vibration ' module in the Module Library. But I did not solved this ' singular matrix ' error. I have attached the file , I hope someone could give me hints or suggestion.
thank you
Abdu
thank you
Abdu
1 Reply Last Post 28.04.2014, 02:23 GMT-4
