Matlab LiveLink - Get Max VanMises Stress
i'm working on an optimisation using a genetic algorithm (matlab) for model generation and comsol multiphysics for solving the fe model (Solid Mechanic with prescribed displacement).
I know how to get solution results at specific coordinates using the command "mphinterp" in matlab. But in this case i want to minimise the maximum value of vanMises Stress in the model. Any ideas how to get this information (Maximum vanMises stress) in matlab (LiveLink)?
I already found out, that there is a way using mpheval which returns a vector with values for all nodes in the model. This vector can be analysed in matlab.
But i hope, there is a more efficient way to ge the maximum of a requested variable directly.
Thanks for your help
Martin
2 Replies Last Post 20.03.2014, 13:12 GMT-4
Lorant Olasz COMSOL Employee
Posted: 1 decade ago 13.03.2014, 11:56 GMT-4
Hi Martin,
In case you have not already found it, adding a Probe (found under Definitions) to the model would be able to get you the maximum value.
Lorant
Hi Martin, In case you have not already found it, adding a Probe (found under Definitions) to the model would be able to get you the maximum value. Best, Lorant
Posted: 1 decade ago 20.03.2014, 13:12 GMT-4
Hi Lorant,
thanks for your reply. I already got this problem solved using the mpheval command and an effective matlab algorithm for picking out relevant stresses (in the meantime it turned out, that the max VanMises stress isn't the only value i need).
Hi Lorant, thanks for your reply. I already got this problem solved using the mpheval command and an effective matlab algorithm for picking out relevant stresses (in the meantime it turned out, that the max VanMises stress isn't the only value i need).
