Surface stress components on arbitrary objects
I want to study the normal, axial and tangential stress components (full tensor) on the side surface or along a circumfering line of a conical object.
This is quite similar to a previous discussion here: www.comsol.com/community/forums/general/thread/34639/, the difference being that I want to use a boundary coordinate system instead of a cylindrical system. I am unable to use the boundary system inside the linear elastic material feature to set up this.
Could someone tell me if this is possible within Comsol and how?
5 Replies Last Post 19.02.2014, 11:10 GMT-5
Posted: 1 decade ago 13.02.2014, 04:13 GMT-5
A boundary system cannot be used in the material definition in a domain, since it is only well-defined on the boundary and not inside the domain.
In your case, the best solution is to create a conical coordinate system of your own using a Base Vector System under Definitions. If you call the (half) cone angle 'alpha', the axis directions would look something like
x1: cos(alpha)*cos(theta), cos(alpha)*sin(theta), -sin(alpha)
x2: -sin(theta), cos(theta), 0
x3: sin(alpha)*cos(theta), sin(alpha)*sin(theta), cos(alpha)
where theta is the angle in the X,Y-plane and Z is the cone axis.
Henrik
Hi, A boundary system cannot be used in the material definition in a domain, since it is only well-defined on the boundary and not inside the domain. In your case, the best solution is to create a conical coordinate system of your own using a Base Vector System under Definitions. If you call the (half) cone angle 'alpha', the axis directions would look something like x1: cos(alpha)*cos(theta), cos(alpha)*sin(theta), -sin(alpha) x2: -sin(theta), cos(theta), 0 x3: sin(alpha)*cos(theta), sin(alpha)*sin(theta), cos(alpha) where theta is the angle in the X,Y-plane and Z is the cone axis. Regards, Henrik
Posted: 1 decade ago 13.02.2014, 12:56 GMT-5
Thank you for the answer!
Could I use such coordinate systems only to get the tensor for one point at a time or is it possible to also do 3D surface plots and 1D stress plots along the surface? How?
Thank you for the answer! Could I use such coordinate systems only to get the tensor for one point at a time or is it possible to also do 3D surface plots and 1D stress plots along the surface? How?
Posted: 1 decade ago 14.02.2014, 02:25 GMT-5
The idea is that the coordinate system is valid everywhere. This assumes that the angle theta is not entered as a parameter, but as a variable like theta = atan2(Y,X).
Henrik
Hi, The idea is that the coordinate system is valid everywhere. This assumes that the angle theta is not entered as a parameter, but as a variable like theta = atan2(Y,X). Regards, Henrik
Posted: 1 decade ago 19.02.2014, 05:08 GMT-5
The cone I am using have the global coordinate z-axis pointing in the direction of the top of the cone. When I use your expressions for the vectors I got a normal vector pointing slightly downwards. Everything seems correct though when changing your original expression x1, z from -sin(alpha) to sin(alpha).
Thank you!
The cone I am using have the global coordinate z-axis pointing in the direction of the top of the cone. When I use your expressions for the vectors I got a normal vector pointing slightly downwards. Everything seems correct though when changing your original expression x1, z from -sin(alpha) to sin(alpha). Thank you!
Posted: 1 decade ago 19.02.2014, 11:10 GMT-5
A remark: The method used here works when you have an simple boundary like a cone so that the coordinate system directions are easy to figure out. If you have a more general boundary like the title "arbitrary objects" indicates, then another method can be considered:
Add a Membrane interface to the model, and put a cladding of very thin membranes on your solid. It will not change the stiffness if the thickness is small enough. The membranes will then capture the 2D stress state on the boundary (which is correct if the surface is traction free). For the membranes, a boundary system can then be used to orient the in-plane stress components.
Henrik
Hi, A remark: The method used here works when you have an simple boundary like a cone so that the coordinate system directions are easy to figure out. If you have a more general boundary like the title "arbitrary objects" indicates, then another method can be considered: Add a Membrane interface to the model, and put a cladding of very thin membranes on your solid. It will not change the stiffness if the thickness is small enough. The membranes will then capture the 2D stress state on the boundary (which is correct if the surface is traction free). For the membranes, a boundary system can then be used to orient the in-plane stress components. Regards, Henrik
