sand ripples simulation
Hi folks,
I am trying to simulate the formation and motion of sand ripples ( sand particles driven with wind). I think that this process may be considered as a two phase flow or a flow of a mixture of sand and air. Specifically, I need to simulate the collision of particles. I have tried particle tracing modules, but the particles do not hit each other- no collision is occurerred. I am also trying the Mixture Model, Laminar Flow Module, and just getting some errors.
I appreciate it if you could share with me your brilliant ideas to help me through the process.
Cheers,
Shayan
5 Replies Last Post 24.07.2014, 22:21 GMT-4
Hello Shayan Bigdeli
Posted: 1 decade ago 19.05.2014, 23:30 GMT-4
Shayan,
Did you figure out how to model particle-particle collision? I'm trying to do almost the same thing you are trying to do.
Shayan, Did you figure out how to model particle-particle collision? I'm trying to do almost the same thing you are trying to do.
Posted: 1 decade ago 12.06.2014, 07:20 GMT-4
I'm having the same problems. I've tried this in the MBD and the Particle tracing module and can't seem to get them to collide. they just pass through each other.
Posted: 10 years ago 20.07.2014, 21:21 GMT-4
Does anyone know something about the particles collision simulation? The same problem. Thanks.
Albert
Hello, Does anyone know something about the particles collision simulation? The same problem. Thanks. Albert
Posted: 10 years ago 24.07.2014, 22:20 GMT-4
Albert
Hi there,
I've found a code which may work for particle collision simulation. I am not sure if I can mention its name here. So, please send me private msg for more details.
Shayan
[QUOTE] Hello, Does anyone know something about the particles collision simulation? The same problem. Thanks. Albert [/QUOTE] Hi there, I've found a code which may work for particle collision simulation. I am not sure if I can mention its name here. So, please send me private msg for more details. Thanks, Shayan
Posted: 10 years ago 24.07.2014, 22:21 GMT-4
Hi folks,
Cheers,
Shayan
Hi there,
Shayan
[QUOTE] Hi folks, I am trying to simulate the formation and motion of sand ripples ( sand particles driven with wind). I think that this process may be considered as a two phase flow or a flow of a mixture of sand and air. Specifically, I need to simulate the collision of particles. I have tried particle tracing modules, but the particles do not hit each other- no collision is occurerred. I am also trying the Mixture Model, Laminar Flow Module, and just getting some errors. I appreciate it if you could share with me your brilliant ideas to help me through the process. Cheers, Shayan [/QUOTE] Hi there, I've found a code which may work for particle collision simulation. I am not sure if I can mention its name here. So, please send me private msg for more details. Thanks, Shayan
