Possible solutions on non-converging solution
I'm doing a solid mechanics model. Basically what I want to achieve is by changing a material stiffness (parameters' values in an energy density function) over time, the material will contract. I first constructed the model at reference state (Ta=0), then I used parametric sweep to increase Ta until 1 (fully contracted) in stepping {range(0,0.05,1)}.
Firstly I used normal sized mesh, then the solution cannot converge at Ta=0.5. Then I used fine size, cannot converge at Ta=0.75. Then I used finer size, surprisingly it cannot converge at Ta only 0.2. Why is like that? I tried also to use a smaller stepping but it didn't help.
After that, I tried to used time-dependent solver and see (fine mesh). Still, the solution failed to converge. All the solver configuration I used: Pardiso (instead of MUMPS), Constant Newton (instead of Automatic Newton).
Anyone know any possible solutions for this? Please help, thanks so much.
CN
0 Replies Last Post 02.01.2014, 04:03 GMT-5
Hello Chin Neng Leong
