quickly changing material or geometry in a multiphysics problem and resolving
Posted 24.06.2009, 14:59 GMT-4 1 Reply
I am experimenting with the "loudspeaker" model in the model library. The procedure to set up and run the model is quite involved and takes a long time, so I am wondering if there is a way to automate the entire solution (including the magnetic, structural, and acoustic steps) so that if I want to make a small change, for example in the geometry or in a material property, then I can get an updated solution automatically.
I would want to see all the intermediate output recomputed, such as the BL factor, the graph for magnetic flux density along the coil, the sensitivity graph, the electrical impedance graph, etc.
What is the easiest way to re-run all these steps after making minor changes to the model and save all these outputs?
Best regards
Alex Salvatti
asalvatt@harman.com
Hello Alex Salvatti
