18.03.2010, 17:01 GMT-4
I would try to multiply the heat source value (amplitude) by a "*sin(2*pi*t)" factor.
But as "t" is only defined in "transient mode" you would get an error message if you switch to back to stationary, without supressing it again.
09.09.2011, 16:32 GMT-4
I am trying to change the external temperature as a sinusoidal function of time. The model is in transient mode, yet i still get the unit error when i simply plug in ext. temp = 280*Sin(t).
I also tried to change it from global expression, but still i get the unit mismatch error. How else can i change the external temperature as a sine function?
Appreciate any help. Thanks
10.09.2011, 05:32 GMT-4
the unit mishmthc is that "t" has units [s] and the operator sin() wants unitless values:
hence you shoud either write a[m]=a0[m]*sin(2*pi*f[Hz]*t[s]) without necessarily all units if already defined
or just sin(t[1/s]) to be unitless
11.09.2011, 13:57 GMT-4
Thanks. It worked.
Thanks. It worked.
