2 decades ago
12.03.2010, 15:55 GMT-5
My way (there are many) is to define a variable "param" as range(0,0.1,1) (typically from 0 to 1) and then I multiply the amplitude of my signal by "*param".
So if you have several electrodes, and you have grouped them into a "group" you can define a BC (boundary condition) as Voltage = Vamplitude*param (Vamplitude being defined i.e. in the Constants as Vamplitude = 10[V] or whateverfits you) and normally off you go
But you can also define the parameter directly as a voltage value, just check the units, as noramlly the parameter is unitless
And when thing fails, try it out on the simplest model you can imagine, to learn the principle behind, one often fails because of the complexity of the multiphysics, its not always just to jump in and "play winner"
2 decades ago
15.03.2010, 07:07 GMT-4
Hello
We have understood how define the parameters of the solver to associate as boundary conditions as parameters. For example, if we take param1=1 param2=0 param3=-1, we can fix a current entering on a first border, an electric insulation on the second and an outgoing current on the third. Thus, the problem will be solved for these boundary conditions. If we add three new values in the window parameter value, Comsol will start up a second resolution, ect…
But in our case, we would wish to associate a set of 1064 boundary conditions (or less if we are able to group them by function: current entering, outgoing, insulation…)with only one value parameter. For that, parameter would be the number of a line of matrix made up of 1064 values. These data could be in an additional file that we call in the window parameter sweep or could be generated by a function connecting a number of parameter has a set of number of border.
It is this passage which we do not manage to format in Comsol.
Thanks for your help!
Hello
04.03.2014, 16:37 GMT-5
Nolwenn, did you ever figure out how to sweep through different electrodes in your model? I have a set combination of current point sources and sinks that I wish to apply in my model, and I wonder whether a parametric sweep can help me do this quickly. I am currently running all ~320 combinations using the Matlab livelink, but it's slow, and I wonder whether using a parametric sweep would speed up some of the model setup for each new combination.
