ECT sensitivity distribution maps
I am using Comsol ver 3.5a Electrostatics module to design my 12 electrode electrical capacitance sensor in 2D. Now i would like to generate a sensitivity map for this ECT sensor but before that would like to transform my 2D model to 3D. So my first question is that how can i transform my 2D model to 3D?
Then after that, how 3D sensitivity distribution (map) could be obtained using COMSOL?
Sensitivity distribution is essentially a map of the sensor response to a short test probe of high permittivity material in a low permittivity background as it located at different x, y and z positions inside the sensor. In principle, the sensitivity distributions can be obtained by physical measurement or by FE analysis. The 3D sensitivity distribution of electrode pair ij,Sij(k) (the subscript i and subscript j indicate that the measurement electrode i and j are the excitation and the
detection electrodes.
Please help me.
Thanks.
4 Replies Last Post 07.05.2013, 00:36 GMT-4
Posted: 1 decade ago 06.05.2013, 11:50 GMT-4
be aware you need quite som eRAM and time to solve when yuo go from 2D to 3D ;)
Have you tried to extrude or revolve your 2D (respectively 2D-axi) geometry (I belive to remember that existing already in 3.5, common now in V4)
Hi be aware you need quite som eRAM and time to solve when yuo go from 2D to 3D ;) Have you tried to extrude or revolve your 2D (respectively 2D-axi) geometry (I belive to remember that existing already in 3.5, common now in V4) -- Good luck Ivar
Posted: 1 decade ago 06.05.2013, 23:45 GMT-4
Yes, I have tried to extrude 2D model to 3D and it does but i dont know what distance value i should choose in Extrude. As I was using 2e-6 but it only shows the top view in 3D, what value i need to key in to observe the whole sensor ?
Thanks for your co-operation.
Areeba
Hi, Yes, I have tried to extrude 2D model to 3D and it does but i dont know what distance value i should choose in Extrude. As I was using 2e-6 but it only shows the top view in 3D, what value i need to key in to observe the whole sensor ? Thanks for your co-operation. Regards, Areeba
Posted: 1 decade ago 07.05.2013, 00:36 GMT-4
And also I would like to know that how could I obtain Sensitivity distribution maps for 12 electrode-electrical capacitance tomography sensor that is filled with air,water and oil.
Can COMSOL be used to obtain the sensitivity maps for ECT in 3D ?
And also I would like to know that how could I obtain Sensitivity distribution maps for 12 electrode-electrical capacitance tomography sensor that is filled with air,water and oil. Can COMSOL be used to obtain the sensitivity maps for ECT in 3D ?
