Failed to evaluate variable in particle tracing module
Hello!
I'm trying to simulate particle temperature in particle tracing module.
But, when I try to plot a line graph of particle temperature, I see this:
Variable - mod1. Tp
Geometry- 1
Boundary-10
Failed to evaluate expression
Can anyone help me with this?
1 Reply Last Post 13.04.2013, 17:12 GMT-4
Posted: 1 decade ago 13.04.2013, 17:12 GMT-4
it is most probably that your Tp is a field or Tp(x,y,z,t), and that Tp has not been defined in your geometry 1 and on bondary 10.
Check also heequation view and see where Tp is volid
Hi it is most probably that your Tp is a field or Tp(x,y,z,t), and that Tp has not been defined in your geometry 1 and on bondary 10. Check also heequation view and see where Tp is volid -- Good luck Ivar
