Ask the question about the particle tracing module.
I have a question when I have used particle tracing module(fpt). Because I try to utilize the condition of Particle-Particle Interaction. I don’t know how to define the interaction force of particle.
E is electric field, in fact, I have already calculated through AC/DC module. rij is the distance vector between the center of particle i and the center of particle j.
I know the function of dest, but I don’t understand how to combine vector E(Vx,Vy) and position(qx,qy).
2 Replies Last Post 03.04.2013, 08:42 MESZ
Posted: 1 decade ago 02.04.2013, 15:30 MESZ
I have a relatively same problem is your problem solved?
Hi, I have a relatively same problem is your problem solved?
Posted: 1 decade ago 03.04.2013, 08:42 MESZ
sorry, so far, I don't have the method to solve this problem. But if I have the idea, I will first tell to you.
[QUOTE] Hi, I have a relatively same problem is your problem solved? [/QUOTE] sorry, so far, I don't have the method to solve this problem. But if I have the idea, I will first tell to you.
