Heat Flux
does any one have been simulation about thermal transmission cable when operation
what module that i can use ? i want to get Heat flux and current when external temperature change
1 Reply Last Post 06.03.2013, 10:46 GMT-5
Posted: 1 decade ago 06.03.2013, 10:46 GMT-5
if its the joule heating by electric currents in all solid material you have the "TEM" physics Joule heating and thermal expansion, but if you want to solve for only T and V then EC electric current and HT heat transfer i solid should do the job
Hi if its the joule heating by electric currents in all solid material you have the "TEM" physics Joule heating and thermal expansion, but if you want to solve for only T and V then EC electric current and HT heat transfer i solid should do the job -- Good luck Ivar
