Connect a pair of concentric helix into one
I'm trying to model an inductor with two concetric layers of windings using two separate helix. The two windings need to be connected in someway and the following methods have been tried:
- Revolving and extruding an end of the first helix to the an end on the second helix gives me an error. I use the measure-tool to find the points of the revolving axis, but I suspect that some value is rounded resulting in a slight shift of the geometry which isn't recognizable by just looking at the screen.
- Since I'm working with Induction Heating I have an option called "Periodic Condition". So I add the two boundaries that I want to connect under "Periodic Condition" and then add the boundary for the second winding under "Destination Selection". The results I get say that the whole geometry has the same temperature which is incorrect.
Are there any other ways I can solve the problem or is there something I'm doing wrong in the above mentioned methods I've already tried?
0 Replies Last Post 25.02.2013, 15:33 MEZ
Hello Bilal Butt
