Peak-to-peak amplitude in Comsol 4.3a ?
I need to evaluate the peak-to-peak (pk-pk) amplitude of a voltage, which means the difference between the maximum positive and the maximum negative of a waveform. Are there any predefined function to do so in Comsol 4.3a, please?
Or are there, at least, any predefined functions to calculate max postive (highest amplitude value) and max negative (lowest amplitude value, which can be negative) of a waveform ? That would be a help too.
I searched the docs and the forums but to no avail.
Thanks very much
1 Reply Last Post 20.02.2013, 13:17 GMT-5
Posted: 1 decade ago 20.02.2013, 13:17 GMT-5
Hi Marouane
Yes you have the max and min operators (Definitions) as well as special opertors max() min() including for postprocessing in the derived values, and, you might use max(T,x) to get the "x" coordinate of the max (or was it max,T,'x') ? check the doc/help (search for max( special operator), I'm not by my WS just now ;)
Most definitions results, as in harmonic mode, are ampliude (0-peak)
Hi Marouane Yes you have the max and min operators (Definitions) as well as special opertors max() min() including for postprocessing in the derived values, and, you might use max(T,x) to get the "x" coordinate of the max (or was it max,T,'x') ? check the doc/help (search for max( special operator), I'm not by my WS just now ;) Most definitions results, as in harmonic mode, are ampliude (0-peak) -- Good luck Ivar
