Flow of two Gases in a reactor
Hello everyone,
I need to perform a simulation, where a hollow rectangular tube is installed with two different inlets (one for Nitrogen and one for Oxygen). The tube will be open from both the ends and placed horizontally. and separate openings are provided on the top surface. Oxygen is going to flow with a pressure of 1.5 bar and 2ltr/min. To constrict this oxygen within the tube, nitrogen gas a both the ends with higher pressure (2-2.5 bar at 5ltr/min) than oxygen will be supplied. The objective of Nitrogen flow is to prevent flow of oxygen into the open surrounding. from the results, it is required to check the molar concentration of oxygen at both the ends. Please give some suggestions.
0 Replies Last Post 17.10.2024, 06:23 GMT-4
Hello Leo James
