Adding damping layer in COMSOL
HI, I also wanna model a damping layer (constrained and unconstrained layer) located to the outer boundary of turbine tower with a specific length (L) along the height of tower (I will do a parametric sweep of L). The problem is that the cylinder is tapered hence I can't easily model the geometry which should be attached to the outer boundary of the tower. I saw I could use linear layer model in the shell physics but the mesh is not computed. Which is the easiest way to do it and more suitable for my case.
0 Replies Last Post 12.09.2024, 04:20 GMT-4
Hello Filippo Tosato
Reply
