22.01.2013, 01:38 GMT-5
My conclusion newer trust one source always verify,
perhaps it's a typo, it's worth to send the remark directly to "support",
But in my 4.3a I read about 1.1448E12[Pa] for E at about 300[K]
So it might have been corrected since
22.01.2013, 01:54 GMT-5
Okay, good they corrected it in 4.3. Just wanted to make sure .
[QUOTE]
[/QUOTE]
Nagi Elabbasi
Facebook Reality Labs
22.01.2013, 11:25 GMT-5
Hi Ivar, I actually find the same value Erik reported in V4.3a which is an order of magnitude too low. Where do you find this higher value?
22.01.2013, 11:50 GMT-5
Hi Nagi
indeed I searched for Diamond, but as I have the full material library I took that one, the "other" one you are referring to is basic materials "C[100]". This is probably NOT diamond but some C crystalline structure (unfortunately no info is given I see)
the "nu" is also quite different
So worth a question to COMSOL support (I leave that to the discoverer ;)
if it's not a typo, COMSOL should update their INFO section to explain what it is, even if it probably is stated somewhere in on of the models, but which one ? (or the material book ?)
Anyhow just a good reminder that one should ALWAYS recheck all data, even when one believes its trustworthy ;)
Hi Nagi
23.01.2013, 22:19 GMT-5
Thanks for the note about diamond material, I am using that one now and the E value looks correct (at room temperature). Eventually I'll post the support about C[100]
Cheers,
Erik
Cheers,
Erik
