How to suppress the 'Error in sweep' message and continue to execute the following code?
Hi, there!
I use livelink for matlab to preform parameter sweep. Through this code
model.batch('p1').set('err', false);
the 'stop if error' box is uncheck. Indeed, comsol will continue with the next parameter value if the current one encounters error.
However, when the parameter sweep is finished, comsol will pass all the error messages to matlab and stop matlab from executing the following post-process codes. Then, I have to execute these codes manually.
I was wondering if there was a way to protect the execution of matlab code from the disturbance of 'Error in sweep' message, so that matlab could running the following post-process codes automatically.
HC
1 Reply Last Post 23.07.2024, 06:33 GMT-4
Posted: 2 weeks ago 23.07.2024, 06:33 GMT-4
Updated: 2 weeks ago 23.07.2024, 06:34 GMT-4
a way that might work is to put the matlab command of 'compute' into a matlab subfunction
Reply
