Implementation of an Initial temperature field using a previously obtained temperature field
Dear all;
I found that Comsol allows a simple equation for the initial temperature field such as T=sin(xy). But, I can not find how to implement some complicated temperature field as an initial temperature field using a previously obtained temperature field.
Sometimes, you may want to use a result (temperature, velocity vector field, etc.) from previously run experiments. How can I use the temperature and/or velocity vector field as initial temperature/velocity field?
Thank you in advance.
Changyeol
1 Reply Last Post 06.12.2012, 14:14 MEZ
Posted: 1 decade ago 06.12.2012, 14:14 MEZ
check the doc for the solver node initial values tab
Hi check the doc for the solver node initial values tab -- Good luck Ivar
