Computing a single study many times with random initial velocity using scripts
Hi there,
I'm currently working on generating a large amount of physics simulation data for a machine learning study. Specifically, I'm using laminar flow and heat transfer in fluids and aim to obtain training data for velocity, temperature, and pressure at each step. I need a substantial dataset that is generated from the same geometry and boundary conditions but with different initial velocity/pressure values.
I'm wondering if there is a script or command line tool that can help me achieve this. Your assistance would be greatly appreciated.
Thank you!
1 Reply Last Post 11.09.2023, 12:12 GMT-4
Posted: 1 year ago 11.09.2023, 12:12 GMT-4
This can probably be done in a parametric sweep. You can use the random function in the range definition of the parametric sweep. A JAVA method could certainly do the same and even more sophisticated but requires coding.
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
